n_damian
Dec 10, 2015Aspirant
Readynas Ultra 2 + 6.4.1?
Hello Anyone have any experience with Ultra 2 + 6.4.1?
JennC
Dec 11, 2015NETGEAR Employee Retired
Hi n_damian,
A lot of legacy ReadyNAS users already did this and it appears to be working.
Check this link so you have idea.
n_damian
Dec 11, 2015Aspirant
Actually on my Ultra 2 + 6.4.0 there is no problem.
Ultra 2 + OS X 6 is not supported so i'm afraid problems.
- StephenBDec 11, 2015Guru - Experienced User
Ultra 2 + OS X 6 is not supported so i'm afraid problems.You can downgrade back to 6.4.0 without a reset. So the risk isn't that high.
I'll spare you the full backup lecture, but if you don't have backups you should.
- JennCDec 11, 2015NETGEAR Employee Retired
Hello n_damian,
The ReadyNAS Utra 2, 2+, 4, 4+ and other legacy x86 NAS are OS4. This Ultra2+ should still work with OS6 if the others do.
Here's an example:
https://community.netgear.com/t5/ReadyNAS-Beta-Release/Netgear-ReadyNAS-Ultra-2-and-OS6/td-p/968922
