barryd
Jan 15, 2016Aspirant
Readynas 102 connection problem with Apple Macs
I have a client in a design studio where we installed a 2 disk (2x3TB) Readynas 102 about a year ago. The PC's on the network see the folders really quickly but the two Macs seem to have a proble...
barryd
Jan 18, 2016Aspirant
Hi
Thanks for the further replies. Sorry but I was away over the weekend.
All they have come back to me so far with is the Readynas firmware version which is 6.1.6
I am going to see if I can get remote access to the mac later today which might speed things up a bit
mdgm-ntgr
Jan 18, 2016NETGEAR Employee Retired
That is very old firmware released almost two years ago.
To apply the change I was thinking of I would need the firmware to be updated to at least 6.2.5, I think.
The logs would be helpful in case there are other factors at play.
- barrydJan 19, 2016Aspirant
Thanks
I will sort out the logs today for you and take it from there. Is it easy to upgrade the firmware and can it be done from the webconsole as I can remote into a local PC to do that?
- StephenBJan 19, 2016Guru - Experienced User
It can be upgraded over the web interface.
Upgrade to 6.2.5 first; don't attempt to go directly to 6.4.x. You can manually download 6.2.5 here: http://downloadcenter.netgear.com/en/product/ReadyNAS-OS6#searchResults
Extract the image file from the zip. Manual installation is done from the system->settings page (at least it is with current firmware).
There are some issues with 6.4.x firmware btw. I recommend updating backups before any firmware update or disk manipulation - but I think its particularly important in your case. So I'd update (or create) a full backup before beginning.
OK thanks
Ill get the operator in the studio to make sure they take a full backup ASAP and they I will try and remote in and do the firmware upgrade.
Will come back to you
Regards
Barry
