barryd
Jan 15, 2016Aspirant
Readynas 102 connection problem with Apple Macs
I have a client in a design studio where we installed a 2 disk (2x3TB) Readynas 102 about a year ago. The PC's on the network see the folders really quickly but the two Macs seem to have a proble...
barryd
Jan 19, 2016Aspirant
Thanks
I will sort out the logs today for you and take it from there. Is it easy to upgrade the firmware and can it be done from the webconsole as I can remote into a local PC to do that?
Jan 19, 2016Guru - Experienced User
It can be upgraded over the web interface.
Upgrade to 6.2.5 first; don't attempt to go directly to 6.4.x. You can manually download 6.2.5 here: http://downloadcenter.netgear.com/en/product/ReadyNAS-OS6#searchResults
Extract the image file from the zip. Manual installation is done from the system->settings page (at least it is with current firmware).
There are some issues with 6.4.x firmware btw. I recommend updating backups before any firmware update or disk manipulation - but I think its particularly important in your case. So I'd update (or create) a full backup before beginning.
- barrydJan 19, 2016Aspirant
OK thanks
Ill get the operator in the studio to make sure they take a full backup ASAP and they I will try and remote in and do the firmware upgrade.
Will come back to you
Regards
Barry
- barrydJan 20, 2016Aspirant
Firmware upgraded now. I think I have to "Run a balance" not sure how to do this.
- StephenBJan 20, 2016Guru - Experienced User
It changed a bit in 6.4.x, so I am working from memory here.
There should be a settings wheel next to the volume icon on the volumes page. Try clicking that. If you don't see balance, but you do see maintenance schedule, click on that option and schedule a balance.
At some point in the past the volume maintenance was on the system settings page, so if you aren't finding the settings wheel then look there too.
Thanks. Will have a look but is it cruicial as I did a search on here and found a few people had had problems after running a balance.
I am 240 miles away from the client and dont want to bring it a halt and have to go down to sort it out.
- mdgm-ntgrJan 20, 2016NETGEAR Employee Retired
I believe the volume maintenance schedule was in a different section of the web admin UI in 6.2.x.
We'd recommend scheduling defrag and balance to run weekly, but at times when the NAS will be used lightly.
I am not doubting you but they tell me its been very slow connecting from the Macs since it was installed over a year ago. The PC's on the network have no problem accessing it instantly.
- barrydJan 22, 2016Aspirant
MDGM has been helping me with this issue and is trying hard to resolve it. He made some changes in the backend to the SMB protocols but sadly it has made no difference.
The client this morning reported that there is no change in the connection speed from the Macs. It is taking about three minutes to open a folder on a share from the mac and its pretty instant on the PC next to it. I even got them to swap the PC and Mac ethernet cables to see if it was that but just the same. PC quick, Mac Slow.
I am at a loss as to what to try next. I did find a couple of threads where there were similar issues with Apple products and Readynas but no real solutions. There must be thousands of users with Apple and readynas though.
Any further ideas greatly appreciated.
- barrydJan 23, 2016Aspirant
Just another thought. I logged into the Nas remotely today and clicked on the SMB setting. Even though it was green it said do I want to enable it for workgroupl VOLUME. Ive just left it for now. Is it enabled?
Also could it be a Workgroup or DNS issue? I have a recolection in my alded old brain of a similar problem some years ago where (I think it was a PC) was going off searching the internet for a share before realising it was local and finding it on the local network. All the PC's are within a Windows 7 Workgroup as well.
Just now when I remoted into a PC at the site I clicked on Networks and the available PC's came up in windows explorer but the readynas was last and took about 40 seconds to appear. After that it was instant and the shortcut on the PC is always instant.
I think its a network issue somewhere. I dont think there is anything wrong with the Readynas. I asked the Mac users to leave the two Macs on so I could try a few things but sadly they must have gone to sleep and I cannot remote in over the weekend but will see if I can get them to stay awake next week.
Any thoughts on this or am I clutching at straws?
One more thing. Would installing Raidar on the Mac help?
- StephenBJan 23, 2016Guru - Experienced User
-If you can access the NAS shares from file explorer in the Windows PCs, then SMB is enabled.
-It is best to have all the PCs and the NAS in the same workgroup. There is an old guide for doing that with macs here: http://www.digitalcitizen.life/how-change-workgroup-mac-os-x-easy-networking I'm not a mac user, so I don't know if the guide works with current OSX.
-If "check for updates" succeeds in the NAS web ui, then you have a good DNS configuration already.
-Not sure if RAIDar 4.3.8 installation on the mac accomplishes, but it does no harm.
