barryd
Jan 15, 2016Aspirant
Readynas 102 connection problem with Apple Macs
I have a client in a design studio where we installed a 2 disk (2x3TB) Readynas 102 about a year ago. The PC's on the network see the folders really quickly but the two Macs seem to have a proble...
vbif
Feb 05, 2016Aspirant
so, I've played with vfs objects and it seems to be working form me...
in the SAMBA config file (log over ssh onto your NAS as root)
/etc/frontview/samba/Shares.conf
I've put in "vfs objects" for each share
for Example
[Download] vfs objects = fruit streams_xattr path = /DATA/Download comment = "" .....
I'm not sure if it the right way to do, or may be my mac has actually cached all the files local due to my tests... but it seems to be working.... and of course you should turn off Preview Feature in Finder on each Mac to speed up the access time
something like this http://blog.skynet-solutions.net/post/52968299699/photoshop-could-not-save-file-because-write-access
and one more thing, this file will be overwritten as soon as you change your shares configuration over the web interface, perhaps it will work also in the file that shall not be overwritten
smb.conf.overrides
but i didn't test that...
barryd
Feb 09, 2016Aspirant
I think mdgm tried this on the back end but perhaps he could confirm what he tried.
Still getting nowhere with this issue.
- barrydFeb 10, 2016AspirantHi The problems are just getting worse. The end user went and upgraded to firmware 6.4.2 and since then the backup has not worked. It has just crashed the entire system during the backup. They couldnt even power off the unit and had to unplug the power. They are now asking me if the can revert back to the previous firmware as the backup worked then. I wasnt sure if I should start a new thread for this or not. Any suggestions?
