barryd
Jan 15, 2016Aspirant
Readynas 102 connection problem with Apple Macs
I have a client in a design studio where we installed a 2 disk (2x3TB) Readynas 102 about a year ago. The PC's on the network see the folders really quickly but the two Macs seem to have a proble...
barryd
Feb 10, 2016Aspirant
I think they were on 6.2.5 (I think) presumably there will be a log somewhere? The anti virus wasnt enabled before but I can check.
Feb 10, 2016Guru - Experienced User
The old firmware version should be in the logs.
If AV is enabled, it will kill performance. So check that first.
Going back to 6.2.x is a multi-step process, and unfortunately requires a factory reset (recovering all data from backup). Netgear does not recommend it, but there are a couple users here who have done it. It's probably better to avoid moving back if you can.
One alternative is to try 6.4.0 first (which can be simply installed).
Or do a reset with 6.4.2, and see if that resolves the connection problem also.
- barrydFeb 10, 2016AspirantAV is not enabled but I cannot find anything in the logs to say what the previous firmware version was. I am pretty sure though I upgraded it to 6.2.5 a couple of weeks back when working with mdgm. They have plugged in a formatted USB drive and are going to let it run tonight on the schedule. I had a google and it seems others have had similar issues with backup since upgrading to 6.4 One step forward and two back it seems.
- StephenBFeb 10, 2016Guru - Experienced User
I had a small backup glitch after I restored my configuration on 6.4.2. The problem was that the scheduled backup jobs weren't running - disabling the schedule and re-enabling it was enough to solve it.
One thing you could try to do is recreate the backup jobs (a bit painful, and any incremental jobs would need to make the full backup first).
- barrydFeb 11, 2016Aspirant
Just had an email from the client to say the nas has frozen again when trying to do the backup over night. Backup light is flashing but they have no access to the Nas and the power off button does nothing. All they can do is unplug the power!
This is not a good situation. I guess I will have to delete or suspend (is that possible?) the backup job until we can rectify the backup problem thats causing the crashing.
