barryd
Jan 15, 2016Aspirant
Readynas 102 connection problem with Apple Macs
I have a client in a design studio where we installed a 2 disk (2x3TB) Readynas 102 about a year ago. The PC's on the network see the folders really quickly but the two Macs seem to have a proble...
brosnahan1114
Feb 29, 2016Aspirant
Can someone summarize the final solution to this problem and the steps neeced to correct it?
BrianL2
Feb 29, 2016NETGEAR Employee Retired
Hi brosnahan1114,
Welcome to the community!
Can you tell us which Firmware and unit are you using? Are you having trouble with the performance (SMB/CIFS or AFP)?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
- brosnahan1114Feb 29, 2016Aspirant
I'm running the ReadyNAS 102 with Firmware 6.4.2, accessing it from a Mac OS 10.10.5. I'm having trouble with the performance where when I open a folder, it could take a couple of minutes for the contents to display. Both are connected by wire to a Netgear R7000 router. There is also a Win10 laptop which is running wireless, which can display the contents of the folders in seconds.
Thank you
- BrianL2Feb 29, 2016NETGEAR Employee Retired
Hi brosnahan1114,
Is Antivirus enabled? In MAC, you can use two file sharing protocols (namely SMB/CIFS and AFP) in accessing your files.
Kind regards,
BrianL
NETGEAR Community Team - brosnahan1114Feb 29, 2016Aspirant
antivirus is disabled. I tried both SMB and AFP, both ways produce the same results
Hi brosnahan1114,
Have you reported this problem to NETGEAR support? I will run some tests and let you know the result.
Kind regards,
BrianL
