barryd
Jan 15, 2016Aspirant
Readynas 102 connection problem with Apple Macs
I have a client in a design studio where we installed a 2 disk (2x3TB) Readynas 102 about a year ago. The PC's on the network see the folders really quickly but the two Macs seem to have a proble...
brosnahan1114
Feb 29, 2016Aspirant
I have not reported to netgear support. I'm a new user and have been getting used the device. I experienced the performance lag and decided to do a little research, which led me to this thread.
I will report to netgear support while I investigate this further.
Thanks
Thanks
- barrydMar 01, 2016Aspirant
ThanksProbably best you start your own new thread rather than hijack this one. However my thread here may help you as I had exactly the same problem. https://community.netgear.com/t5/Using-your-ReadyNAS/Readynas-102-connection-problem-with-Apple-Macs/td-p/1034635 Your issue is a Finder problem. Its a bug introduced to the Apple OS which Apple have so far refused to acknowledge or fix. There is a fix that can be implemented to the firmware called vfs_fruit which fixes the problem somewhat.
brosnahan1114
Please accept my apoligies. I got my threads mixed up. Your input here is relevant. Sorry.
- brosnahan1114Mar 02, 2016Aspirant
barryd,
No need to appologize. I really didn't want to hijack your thread, which seems really important for you to address for your client, but I figured my problem was the same thing you/your client was experiencing.
Hopefully I will be able to get this resolved shortly.
