barryd
Jan 15, 2016Aspirant
Readynas 102 connection problem with Apple Macs
I have a client in a design studio where we installed a 2 disk (2x3TB) Readynas 102 about a year ago. The PC's on the network see the folders really quickly but the two Macs seem to have a proble...
brosnahan1114
Feb 29, 2016Aspirant
I have not reported to netgear support. I'm a new user and have been getting used the device. I experienced the performance lag and decided to do a little research, which led me to this thread.
I will report to netgear support while I investigate this further.
Thanks
Thanks
barryd
Mar 01, 2016Aspirant
Thanks
Probably best you start your own new thread rather than hijack this one. However my thread here may help you as I had exactly the same problem. https://community.netgear.com/t5/Using-your-ReadyNAS/Readynas-102-connection-problem-with-Apple-Macs/td-p/1034635 Your issue is a Finder problem. Its a bug introduced to the Apple OS which Apple have so far refused to acknowledge or fix. There is a fix that can be implemented to the firmware called vfs_fruit which fixes the problem somewhat.
- barrydMar 01, 2016Aspirant
brosnahan1114
Please accept my apoligies. I got my threads mixed up. Your input here is relevant. Sorry.
- brosnahan1114Mar 02, 2016Aspirant
barryd,
No need to appologize. I really didn't want to hijack your thread, which seems really important for you to address for your client, but I figured my problem was the same thing you/your client was experiencing.
Hopefully I will be able to get this resolved shortly.
- brosnahan1114Mar 10, 2016Aspirant
I figured I would check back in here and give an update.
I opened a case with Netgear support. It got elevated to L2 Support. Supports resolution was to get a faster hard drive and create smaller directories so the Mac OSX Finder doesn't have to work so hard to display the results.
Now I will say that this tech kept saying that this is a workaround. I did bring up the contents of this thread in my case, so I can't say I'm really buying this workaround.
The tech closed this case, so I will now have to go another route to solve this with a better workaround.
