barryd
Jan 15, 2016Aspirant
Readynas 102 connection problem with Apple Macs
I have a client in a design studio where we installed a 2 disk (2x3TB) Readynas 102 about a year ago. The PC's on the network see the folders really quickly but the two Macs seem to have a proble...
medoc
Jul 13, 2016Aspirant
*problem
- BrianL2Jul 13, 2016NETGEAR Employee Retired
Hi medoc,
Could you further describe your problem with your ReadyNAS system or perhaps start a new thread?
Kind regards,
BrianL
NETGEAR Community Team- medocJul 14, 2016Aspirant
Hi,
actually we are using a Readynas 104, but I think it shouldn't matter really.
The symptoms are similar.
When trying to access shared folders and files in these shares 3 things happen:
- everything is OK - everyone is happy
- folder is accessible but slow - opening files can take very long or even fails
- cannot access folder. On macs the error message is "The operation can't be completed because the original item for "WORK" can't be found."
Thanks,
medoc
- BrianL2Jul 14, 2016NETGEAR Employee Retired
Hi medoc,
Can you confirm if "WORK" is a share or the Workgroup name of your ReadyNAS system? Also, is the system up to date?
Kind regards,
BrianL
