barryd
Jan 15, 2016Aspirant
Readynas 102 connection problem with Apple Macs
I have a client in a design studio where we installed a 2 disk (2x3TB) Readynas 102 about a year ago. The PC's on the network see the folders really quickly but the two Macs seem to have a proble...
BrianL2
Jul 13, 2016NETGEAR Employee Retired
Hi medoc,
Could you further describe your problem with your ReadyNAS system or perhaps start a new thread?
Kind regards,
BrianL
NETGEAR Community Team
medoc
Jul 14, 2016Aspirant
Hi,
actually we are using a Readynas 104, but I think it shouldn't matter really.
The symptoms are similar.
When trying to access shared folders and files in these shares 3 things happen:
- everything is OK - everyone is happy
- folder is accessible but slow - opening files can take very long or even fails
- cannot access folder. On macs the error message is "The operation can't be completed because the original item for "WORK" can't be found."
Thanks,
medoc
- BrianL2Jul 14, 2016NETGEAR Employee Retired
Hi medoc,
Can you confirm if "WORK" is a share or the Workgroup name of your ReadyNAS system? Also, is the system up to date?
Kind regards,
BrianL
NETGEAR Community Team - BrianL2Jul 14, 2016NETGEAR Employee Retired
Hi medoc,
Was the problem evident in both SMB and AFP protocols? Also, have you considered updating to 6.5.0 or 6.5.1?
Kind regards,
BrianL
NETGEAR Community Team- medocJul 15, 2016Aspirant
We primarly use SMB because of the mixed environment (there are PC-s as well) but have tried AFP when the problem arose. And I can confirm that it affects both SMB and AFP.
We plan to update to the newest firmware, but as I mentioned this problem survived previous updates already.
- BrianL2Jul 17, 2016NETGEAR Employee Retired
Hi medoc,
Since you are still using an older firmware (6.4.2), can you confirm if the AV service is still enabled? If yes, kindly disable it and see if the SMB performance improves. I also suggest that you check this FAQ page.
Kind regards,
BrianL
