peterbarbosa
Jan 31, 2012Aspirant
ReadyNAS 1100 dropping connection from network
Hi everyone, I have a ReadyNAS 1100 which has worked pretty well up until recently. I have my Server 2003 domain controller configured with it. I have a folder redirection policy in place for all u...
peterbarbosa
Feb 01, 2012Aspirant
Yes, here is what that log reads...
If in this case it is a failing channel, what are the next steps? And what does this necessarily mean?
Thanks in advance.
0_sata_xraidecc: 0
0_sata_retry: 0
0_sata_power_glitch: 0
0_sata_hot_add: 0
0_sata_hot_remove: 0
0_sata_lp_stat: 6066
0_sata_reset: 0
1_sata_xraidecc: 0
1_sata_retry: 0
1_sata_power_glitch: 0
1_sata_hot_add: 0
1_sata_hot_remove: 0
1_sata_lp_stat: 9570
1_sata_reset: 0
2_sata_xraidecc: 0
2_sata_retry: 0
2_sata_power_glitch: 0
2_sata_hot_add: 0
2_sata_hot_remove: 0
2_sata_lp_stat: 14741
2_sata_reset: 0
3_sata_xraidecc: 0
3_sata_retry: 0
3_sata_power_glitch: 0
3_sata_hot_add: 0
3_sata_hot_remove: 0
3_sata_lp_stat: 54
3_sata_reset: 0
0_gmac_falsecarrier: 818
0_gmac_symbolerror: 7
0_gmac_disconnect: 2
0_gmac_rcverror: 0
0_gmac_autonegotiation: 2
0_gmac_link_fail: 0
0_gmac_idleerror: 1275
0_gmac_vlan_tags: 0
0_gmac_bad_packet: 1
tcp_retransmit: 94485
tcp_retransmit_unrecovered: 3560
1_gmac_falsecarrier: 54
1_gmac_symbolerror: 3
1_gmac_disconnect: 1
1_gmac_rcverror: 0
1_gmac_autonegotiation: 2
1_gmac_link_fail: 0
1_gmac_idleerror: 510
1_gmac_vlan_tags: 0
Thanks in advance.
