Coolfeather2's avatar
Coolfeather2
Readynas 214 Remote Connection without ReadyCloud?
Wondering if its possible to remote connect to the nas on windows and linux OS for when I go to tafe this year and need to backup files
  • FramerV's avatar
    FramerV
    NETGEAR Employee Retired
    Hi Coolfeather2,
    Welcome to the community.
    You could consider using FTP or HTTP over the internet. This will involve opening/forwarding of ports on your firewall.
    • Sandshark's avatar
      Sandshark
      Sensei - Experienced User
      What type of backup, manual or via some backup program?  For manual backups, HTTP or FTP is an option.  If by backup software that can't use either of those, you might want to look at ZeroTier (do a search of the forum) or another VPN solution.
      • StephenB's avatar
        Coolfeather2 wrote:
        Both FTP and HTTP are not secure, I am manually backing up
        The NAS does support FTPS connections from an FTP client (and there is a setting to mandate FTPS) -  so you can make that secure.
        ZeroTier, OpenVPN and OwnCloud are all possibilities for remote access.
ProSupport for Business
