Froglet0
Sep 12, 2021Aspirant
ReadyNAS 214 Volume degraded Replacement disk showing state UNKNOWN
Disk 4 failed. Replaced and started to resynch. Then stopped and said volume degraded. Attempted formatting drive, powering off and on NAS. Somtimes it would re-start a synch and then stop again. Sometimes it would create an additional volume data-0 that had to be deleted.
It is now sitting in the following state:
Volume is degraded, and volume size appears to represent the size with 3 of the 4 disks.
Volumne settings, however, list all 4 disks.
Disks 1 to 3 are ONLINE, Disk 4 is UNKNOWN
In the overview Disk 4 shows blue but without the Green indicator. Disk cannot be selected for format.
In the background I can hear the NAS churing the disks.
Is this system still recovering, or is it now unrecoverable?
Can I resolve the volumne degraded state by selectively deleting data, or does it need a factory reset?
Firmware: 6.10.5 Hotfix 1
Log extract:
[21/09/09 23:07:16 WEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[21/09/10 01:27:28 WEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[21/09/10 07:48:32 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model:ST8000VN004-2M2101 Serial:WKD2LAF5 was added to Channel 4 of the head unit.
[21/09/10 07:50:06 WEST] info:volume:LOGMSG_DELETE_VOLUME Volume data-0 was deleted from the system.
[21/09/10 08:34:40 WEST] notice:volume:LOGMSG_RESILVERCOMPLETE_DEGRADED_VOLUME The resync operation finished on volume data. However, the volume is still degraded.
[21/09/10 11:13:13 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model:ST8000VN004-2M2101 Serial:WKD2LAF5 was added to Channel 4 of the head unit.
[21/09/10 11:14:09 WEST] info:volume:LOGMSG_FORMAT_VOLUME_SUCCESS Disk format completed on channel 4.
[21/09/10 11:14:14 WEST] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[21/09/10 11:39:16 WEST] notice:volume:LOGMSG_RESILVERCOMPLETE_DEGRADED_VOLUME The resync operation finished on volume data. However, the volume is still degraded.
[21/09/10 12:30:07 WEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[21/09/10 12:36:53 WEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[21/09/10 12:37:55 WEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[21/09/11 01:02:49 WEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[21/09/11 19:40:12 WEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[21/09/11 19:47:47 WEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[21/09/11 20:00:42 WEST] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[21/09/11 20:36:33 WEST] notice:volume:LOGMSG_RESILVERCOMPLETE_DEGRADED_VOLUME The resync operation finished on volume data. However, the volume is still degraded.
[21/09/12 01:07:01 WEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
disk_info.log
Device: sda
Controller: 0
Channel: 0
Model: ST8000VN004-2M2101
Serial: WKD1A746
Firmware: SC60
Class: SATA
RPM: 7200
Sectors: 15628053168
Pool: data
PoolType: RAID 5
PoolState: 3
PoolHostId: 6db84bfc
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Command Timeouts: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 48
Start/Stop Count: 32
Power-On Hours: 10039
Power Cycle Count: 32
Load Cycle Count: 54948
Device: sdb
Controller: 0
Channel: 1
Serial: WKD18S54
Firmware: SC60
Class: SATA
RPM: 7200
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Command Timeouts: 0
Temperature: 53
Load Cycle Count: 55105
Device: sdc
Controller: 0
Channel: 2
Serial: WKD1REXC
Firmware: SC60
Class: SATA
RPM: 7200
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Command Timeouts: 0
Temperature: 54
Start/Stop Count: 20
Power-On Hours: 7919
Power Cycle Count: 20
Load Cycle Count: 38644
Device: sdd
Controller: 0
Channel: 3
Serial: WKD2LAF5
Firmware: SC60
Class: SATA
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Do you have an up-to-date backup of your data? If not, I think making a backup is the next step.
- Froglet0Aspirant
Hi Stephen,
No, I don't have a backup. The NAS is used to backup various home laptops and I don't have anything with similar capacity to back it up to. If I loose the data, it just means I loose a series of old backups.
Bit annoying as I have a couple of ReadyNAS and each has suffered a disk failure and neither has recovered from it properly. Suggests the RAID implementation is poor.
Further problem is that the warranty replacement Seagate IronWolf disk is a refurbished unit and that appears to now be reporting errors.
Sep 11, 2021 08:17:10 PM Disk: Detected high command timeouts: [47] on disk 4 (Internal) [ST8000VN004-2M2101, WKD2LAF5]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy. Sep 11, 2021 07:46:47 PM Disk: Detected high command timeouts: [44] on disk 4 (Internal) [ST8000VN004-2M2101, WKD2LAF5]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy. Sep 10, 2021 12:36:53 PM Disk: Detected high command timeouts: [43] on disk 4 (Internal) [ST8000VN004-2M2101, WKD2LAF5]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy. - StephenBGuru - Experienced User
The RAID implementation is a standard linux tool called MDADM. Though I agree that the actual status doesn't seem to be properly reported in the admin web ui.
Sep 11, 2021 08:17:10 PM Disk: Detected high command timeouts: [47] on disk 4 (Internal) [ST8000VN004-2M2101, WKD2LAF5]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy. Sep 11, 2021 07:46:47 PM Disk: Detected high command timeouts: [44] on disk 4 (Internal) [ST8000VN004-2M2101, WKD2LAF5]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy. Sep 10, 2021 12:36:53 PM Disk: Detected high command timeouts: [43] on disk 4 (Internal) [ST8000VN004-2M2101, WKD2LAF5]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy. I'd contact them and tell them that the replacement disk isn't working correctly. This could well be the actual problem, not a "further problem"
You could try running the disk test from the volume settings wheel. It might also be useful if you could download the full log zip file, and post mdstat.log (copy/paste it into your reply).
