Skaigh
Jan 04, 2018Aspirant
ReadyNAS 3138 has error message Bond interface bond0 has slave interface eth3 offline
After a firmware update to 6.9.0 I received and error message saying
Bond interface bond0 has slave interface eth3 offline. I then updated the firmware to 6.9.1 but am still getting the same error message.
Extract from logs attached.
Hi Skaigh
It should be resolved but it would be better to make sure that all connections are working.
Kindly let me know if it indeed is the cause of the problem.
Regards
- SkaighAspirant
Hi Marc,
Thanks for reply. I have checked the physical connections and I think I have found the problem.
Someone had removed the eth 0 plug from the NAS drive! But becuase our server cabinate is on the wall, high up, it was very difficult to see.
I will check the logs again tomorrow just to ensure this has been resolved.
Many thanks
