Bilal-Hasan
Dec 14, 2016Aspirant
ReadyNas 3220 Hang every few days!
Hello, Could you please assist us to find out why our new device ReadyNas 3220 keep hanging every few days! we have to restart it to bring it to life again! We are using this device for savin...
mdgm-ntgr
Dec 15, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
How many machines are you backing up? Do you stagger the backups?
Which firmware are you running?
Is the NAS used for other tasks or just for your storing your Acronis backups?
Bilal-Hasan
Dec 18, 2016Aspirant
I send you the logs as "Sending Logs" instructions
We are backing up about 40 computers and 2 servers
ReadyNas 3220 firware version : 6.6.0
We are using the NAS for only storing Acronis backup
- mdgm-ntgrDec 19, 2016NETGEAR Employee Retired
The logs don't go back very far unfortunately and the most recent power cycle was a graceful restart not a crash. It's best if you download the logs ASAP after a crash.
You are using NAS disks designed for desktop NAS units not a 12-bay rackmount.You should be using an enterprise NAS HDD or some other enterprise disk. We do have a compatibility list.
Also it appears you have disk spin-down enabled which is quite an odd configuration for a rackmount unit with NAS class HDDs.- Bilal-HasanDec 22, 2016Aspirant
I send you an updated logs after the devices stopped again today!
Thanks,
Bilal
- mdgm-ntgrJan 02, 2017NETGEAR Employee Retired
Those logs show it was restarted normally i.e. it did not hang.
