hungoverdrawn
Jan 05, 2018Aspirant
ReadyNAS Duo v1 not responsive - stuck on RAID resync?
A while ago I got an email from my seven year-old ReadyNAS which has 2 x Western Digital Caviar Green 2 TB Desktop Hard Drive (WD20EARS): "Access to the disk on channel (??) is producing I/O error...
hungoverdrawn
According to RAIDar the resync is stuck on 0.0% (see attached), though as I say before it became unresponsive it was showing as in progress in Frontview.
As it's unresponsive and I can't currently access my data, I guess there's nothing to be lost by powering it down and pulling a drive. Will it come up with only one drive in the enclosure, and does it need to be in slot 1?
Thanks again.
Jan 05, 2018Guru - Experienced User
It should come up with only one drive, in either slot. I'd pull disk 1 after you power it down, as that would let you extract the data if needed (as I described above).
