motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi,
I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed:
Fri Oct 12 17:12:13 WEST 2012 Problem encountered while updating your ReadyNAS device.
These are the ReadyNAS details:
Model: ReadyNAS Duo [X-RAID]
Firmware: RAIDiator 4.1.6 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
Other than that, everything else seems to be working fine.
Thanks
MT
Thanks
MT
- mdgm-ntgrNETGEAR Employee RetiredSo the update didn't take place?
- motah33AspirantNope, it doesn't look like it has. It seems to have just rebooted as normal and that's it.
- motah33AspirantThe first command went in immediately. Then I typed reboot and it rebooted as normal.
- mdgm-ntgrNETGEAR Employee RetiredVery odd.
What's the output of the following?:
# ls -la /
# cat /.cf_update_in_progress - motah33Aspirant
readynas:~# ls -la /
total 121
drwxr-xr-x 22 root root 4096 Oct 21 06:58 .
drwxr-xr-x 22 root root 4096 Oct 21 06:58 ..
lrwxrwxrwx 1 root root 9 Nov 1 2008 backup -> /c/backup
lrwxrwxrwx 1 root root 14 Nov 2 2009 backup-adam -> /c/backup-adam
lrwxrwxrwx 1 root root 14 Nov 2 2009 backup-omar -> /c/backup-omar
drwxr-xr-x 2 root root 4096 Oct 21 06:57 bin
drwxrwxrwx 11 root root 16384 Oct 12 07:47 c
-rw-r--r-- 1 root root 22 Oct 21 06:56 .cf_update_in_progres
drwxr-xr-x 9 root root 24576 Oct 21 06:57 dev
drwxr-xr-x 51 admin admin 4096 Oct 21 06:58 etc
drwxr-sr-x 6 admin admin 4096 Jul 15 2010 frontview
drwxrwsr-x 3 root root 4096 Sep 19 2003 home
drwxr-xr-x 2 root root 1024 Oct 21 06:57 initrd
-rw-r--r-- 1 root root 0 Oct 21 06:57 .init_start
lrwxrwxrwx 1 root root 8 Jan 5 2009 islam -> /c/islam
drwxr-xr-x 7 root root 4096 Jul 15 2010 lib
drwx------ 2 root root 16384 Jul 15 2002 lost+found
drwxr-xr-x 2 root root 4096 Feb 8 2002 mnt
drwxr-xr-x 3 admin admin 4096 Jul 13 2009 opt
lrwxrwxrwx 1 root root 8 Jan 4 2009 photo -> /c/photo
dr-xr-xr-x 55 root root 0 Dec 1 2003 proc
drwxrwxrwt 2 root root 0 Oct 21 07:05 ramfs
drwx------ 4 root root 4096 Jul 15 2010 root
drwxr-xr-x 2 root root 4096 Jul 15 2010 sbin
-rw-r--r-- 1 root root 2 Oct 21 06:57 .sync_start
drwxr-xr-x 11 root root 0 Dec 1 2003 sys
drwxrwxrwt 4 root root 4096 Oct 21 06:57 tmp
lrwxrwxrwx 1 root root 11 Jan 6 2009 transfer -> /c/transfer
drwxrwxrwt 2 root root 40 Oct 21 06:57 USB
drwxr-xr-x 11 root root 4096 May 9 2008 usr
drwxr-xr-x 17 root root 4096 May 15 2006 var
readynas:~# cat /.cf_update_in_progress
cat: /.cf_update_in_progress: No such file or directory - mdgm-ntgrNETGEAR Employee RetiredSee the file /.cf_update_in_progres ? Like I suspected you make a mistake entering the command. There should be two s's in progress.
- motah33AspirantYes, I just realised - missed the 's' out:
/tmp/RAIDiator-4.1.10 - motah33AspirantJust renamed it to what it should be. :)
- mdgm-ntgrNETGEAR Employee RetiredReboot and the update should take place this time.
- motah33AspirantRebooting...
