motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi,
I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed:
Fri Oct 12 17:12:13 WEST 2012 Problem encountered while updating your ReadyNAS device.
These are the ReadyNAS details:
Model: ReadyNAS Duo [X-RAID]
Firmware: RAIDiator 4.1.6 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
Other than that, everything else seems to be working fine.
Thanks
MT
Thanks
MT
- motah33AspirantYep, definitely doing something now... blue light is flashing away.
- mdgm-ntgrNETGEAR Employee RetiredThe unit would also come and go from RAIDar (http://kb.netgear.com/app/answers/detail/a_id/20684/). If you use RAIDar quick enough you should see updating (or something like that) in the Info (far right) column.
- motah33AspirantYep, I can see "updating" in the last column.
- motah33AspirantIt's done but if I hit the rescan on RAIDar it still shows 4.1.6.
- motah33AspirantMust go now. Pick this up later on if you have time. Appreciate all the help.
- mdgm-ntgrNETGEAR Employee RetiredVery odd.
Can you do
# cat /etc/raidiator_version
# cat /var/log/raidiator_version
# ls -la /
Do you see more examples of this?:motah33 wrote:
Oct 21 03:24:46 readynas kernel: Creating 2 MTD partitions on "NAND 64MiB 3,3V 8-bit":
Oct 21 03:24:46 readynas kernel: 0x00000000-0x00100000 : "P0 flash partition 1"
Oct 21 03:24:46 readynas kernel: 0x00100000-0x04000000 : "P0 flash partition 2"
Oct 21 03:24:46 readynas kernel: NEON flash: probing 8-bit flash bus
Oct 21 03:24:46 readynas kernel: CFI: Found no NEON flash device at location zero
Oct 21 03:24:46 readynas kernel: NEON flash: unknown flash device, mfr id 0x1, dev id 0x0
Oct 21 03:24:46 readynas kernel: NEON flash: Found no Atmel device at location zero
Oct 21 03:24:46 readynas kernel: This board is not supported. - motah33Aspirantreadynas:~# cat /etc/raidiator_version
RAIDiator!!version=4.01c1-p6,time=1247518584
readynas:~# cat /var/log/raidiator_version
RAIDiator!!version=4.1.6,time=1247518584
readynas:~# ls -la /
total 121
drwxr-xr-x 22 root root 4096 Oct 22 02:28 .
drwxr-xr-x 22 root root 4096 Oct 22 02:28 ..
lrwxrwxrwx 1 root root 9 Nov 1 2008 backup -> /c/backup
lrwxrwxrwx 1 root root 14 Nov 2 2009 backup-adam -> /c/backup-adam
lrwxrwxrwx 1 root root 14 Nov 2 2009 backup-omar -> /c/backup-omar
drwxr-xr-x 2 root root 4096 Oct 22 02:27 bin
drwxrwxrwx 11 root root 16384 Oct 12 07:47 c
drwxr-xr-x 9 root root 24576 Oct 22 02:27 dev
drwxr-xr-x 51 admin admin 4096 Oct 22 02:28 etc
drwxr-sr-x 6 admin admin 4096 Jul 15 2010 frontview
drwxrwsr-x 3 root root 4096 Sep 19 2003 home
drwxr-xr-x 2 root root 1024 Oct 22 02:27 initrd
-rw-r--r-- 1 root root 0 Oct 22 02:27 .init_start
lrwxrwxrwx 1 root root 8 Jan 5 2009 islam -> /c/islam
drwxr-xr-x 7 root root 4096 Jul 15 2010 lib
drwx------ 2 root root 16384 Jul 15 2002 lost+found
drwxr-xr-x 2 root root 4096 Feb 8 2002 mnt
drwxr-xr-x 3 admin admin 4096 Jul 13 2009 opt
lrwxrwxrwx 1 root root 8 Jan 4 2009 photo -> /c/photo
dr-xr-xr-x 57 root root 0 Dec 1 2003 proc
drwxrwxrwt 2 root root 0 Oct 22 03:03 ramfs
drwx------ 4 root root 4096 Jul 15 2010 root
drwxr-xr-x 2 root root 4096 Jul 15 2010 sbin
-rw-r--r-- 1 root root 2 Oct 22 02:27 .sync_start
drwxr-xr-x 11 root root 0 Dec 1 2003 sys
drwxrwxrwt 4 root root 4096 Oct 22 02:27 tmp
lrwxrwxrwx 1 root root 11 Jan 6 2009 transfer -> /c/transfer
-rw-r--r-- 1 root root 26 Oct 21 07:21 .update_fail
drwxrwxrwt 2 root root 40 Oct 22 02:27 USB
drwxr-xr-x 11 root root 4096 May 9 2008 usr
drwxr-xr-x 17 root root 4096 May 15 2006 var
If I run RAIDar, I can see 4.1.6 as the version number. And yes, I still see those messages about the flash device being unknown.
