DuncanH
Mar 16, 2016Aspirant
ReadyNas NV+ Checking FS stops at 48%
I hope someone can help me, warning I'm not technical !! ReadyNas NV+ v1 - 4 x 2tb drives After running flawlessly for 5 years it decided to do a Check FS when I turned it on, don't think there was...
- Mar 16, 2016
Disk 3 seems to be failing. You could try shutting down the NAS and booting the NAS w/o it.
Mar 16, 2016Guru - Experienced User
It sounds like a failing disk or a volume that has somehow gotten corrupted.
Are you able to see the SMART stats for the drives while it is running (status->health in the web admin page)
- DuncanHMar 16, 2016Aspirant
Thanks for your help.
By Skiping Vol Check can access SMART stats. Didn't have long before lose connection but took a screen grab of each disk.
Don't know what I'm looking for but the big difference comparing the four disks is the Raw Read Error Rate figure which is 0 for Disks 1,2,4 but 60766 for Disk 3. The other difference is Current Pending Sector, Offline Uncorrectable, Multizone Error Rate figures are 0 for Disks 1,2,4 but 5,2,22 respectively for Disk 3.
The Health screen listing the disks shows status OK for all disks.
When I booted it not checking volumes it first says Booting... Disc 4 Sync. Also if I look at Volume setting Status was Resync 6% complete time to finish 49.1 min.
Yes I have a backup of the data I'm pleased to say !!
Again thanks for your help.
