Greigw
Feb 18, 2019Aspirant
ReadyNas nv+ V1 UPS not detected
I have an old ReadyNAS nv+ v1. When I connect it to my UPS - ?? using one of the USB ports on the back Frontview does not show that the ups is detected. But when I unplug the usb cable I get a message in the log and on the front screen of the readynas that the ups has been disconnected.
When the ups is connected, simmulating a power off situation has no effect on the readynas even if it does report the ups is disconnected if I unplug the usb cable after that.
Are there specific types / models of ups I must use with my readynas nv+ v1?
- Retired_Member
Hi Greigw , thanks to Sandshark we know, that (quoting) "ReadyNAS uses NUT (Network UPS Tools) for UPS You can find their compatibility list here: https://networkupstools.org/stable-hcl.html."
Here is the link to the post where this is mentioned: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Netgear-ReadyNAS-RN212-UPS-Options/m-p/1709205#M35242
Kind regards
Note that the NV+ is old, and the version of NUT on it might be dated.
What UPS do you have? What firmware is running on the ReadyNAS?
- GreigwAspirant
Thank you for taking the time to respond.
The following is taken off Frontview:
The UPS is a Proline UPS A650. Which was bought here in South Africa. Probably a rebadged generic model. Internally it is identicle to another UPS I have called a Mecer ME-650-VU+ which has the same characteristics when connected to the Readynas.
I look forward to hearing from you.
- GreigwAspirant
Thanks for responding. See my reply to another response.
Is the cable connecting the NAS to the UPS a normal USB cable?
Or is the UPS output a serial connector that is adapted to USB on the NAS end?
