Dubhaigan
Feb 17, 2018Guide
ReadyNAS NVX Failure - Lost Everything, Please Help
This was my first NAS server and I’ve loved it for the last two years. But I’d gotten it second hand so there was no warranty or registration available. Last night I noticed the fan working pretty ha...
Dubhaigan
Feb 27, 2018Guide
Hey guys, I managed to find another legacy model in really good condition. Since it's the exact same model do I need any sort of migration or can I just swap the disks out as is?
Feb 27, 2018Guru - Experienced User
I suggest first inserting a scratch disk, and doing a test install. Check the firmware, and either match what you had on the old NAS or upgrade to the current firmware (4.2.31).
If that works smoothly, then power down the NVX and reinsert your old disks (ideally in slot order.
- DubhaiganFeb 27, 2018Guide
Thanks very much, I'll do just that!
