Dubhaigan
Feb 17, 2018Guide
ReadyNAS NVX Failure - Lost Everything, Please Help
This was my first NAS server and I’ve loved it for the last two years. But I’d gotten it second hand so there was no warranty or registration available. Last night I noticed the fan working pretty ha...
Feb 27, 2018Guru - Experienced User
I suggest first inserting a scratch disk, and doing a test install. Check the firmware, and either match what you had on the old NAS or upgrade to the current firmware (4.2.31).
If that works smoothly, then power down the NVX and reinsert your old disks (ideally in slot order.
Dubhaigan
Feb 27, 2018Guide
Thanks very much, I'll do just that!
