crond
Nov 02, 2018Aspirant
ReadyNAS OS6 issues with Ultra 4
Hi All,
I'm having trouble with OS6 on latest OS6 firmware and wondering if somebody saw similar issues.
I have Ultra4 with 4x4TB WD Reds. I had no issues on OS4.
Upgrade to latest version went well, but tests showed that data got corrupted (I would copy 200k / 2TB files and than compare md5sums). I tried factory reset and rebuild volume but it didn't help. tried to turn x-RAID off / remove quote experemt with different protocols to transfer (AFP, NFS, rsync) but all results are consistent
After 2 days of reboots/stress testing it finally gave up with kernel crash
[633273.945339] BUG: unable to handle kernel paging request at 000000100000001c [633273.946019] IP: [<ffffffff880dd551>] find_get_entry+0x3a/0x69 [633273.946019] PGD 0 [633273.946019] Oops: 0000 [#1] SMP [633273.946019] Modules linked in: vpd(PO) [633273.946019] CPU: 0 PID: 2247 Comm: afpd Tainted: P O 4.4.140.x86_64.1 #1 [633273.946019] Hardware name: NETGEAR ReadyNAS/ReadyNAS , BIOS 080016 09/20/2010 [633273.946019] task: ffff88003d65d400 ti: ffff880005f24000 task.ti: ffff880005f24000 [633273.946019] RIP: 0010:[<ffffffff880dd551>] [<ffffffff880dd551>] find_get_entry+0x3a/0x69 [633273.946019] RSP: 0018:ffff880005f27c78 EFLAGS: 00010246 [633273.946019] RAX: ffff88001d0af4b0 RBX: ffff88001d140360 RCX: ffff88001d0af4b0 [633273.946019] RDX: ffff88001d0af4b0 RSI: 0000000000073e02 RDI: 0000001000000000 [633273.946019] RBP: ffff880005f27c88 R08: ffff880005f27c60 R09: ffff88001d0af478 [633273.946019] R10: ffff88001d0af4b0 R11: ffffffff88b6449c R12: 0000000000073e02 [633273.946019] R13: ffff88001d140358 R14: 0000000000073e02 R15: 0000000073e00000 [633273.946019] FS: 00007fe51e89b880(0000) GS:ffff88003f000000(0000) knlGS:0000000000000000 [633273.946019] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [633273.946019] CR2: 000000100000001c CR3: 000000000bf92000 CR4: 0000000000000670 [633273.946019] Stack: [633273.946019] 0000000000000007 000000000342004a ffff880005f27cc8 ffffffff880dd5fe [633273.946019] 00000000000178a3 0000000000000002 0000000000000002 ffff88001d1401f0 [633273.946019] ffff8800110d4c10 0000000073e00000 ffff880005f27d30 ffffffff882aa65e [633273.946019] Call Trace: [633273.946019] [<ffffffff880dd5fe>] pagecache_get_page+0x25/0x176 [633273.946019] [<ffffffff882aa65e>] prepare_pages+0x7b/0x14a [633273.946019] [<ffffffff882ab7dc>] __btrfs_buffered_write.isra.6+0x227/0x51b [633273.946019] [<ffffffff8809e963>] ? current_fs_time+0x20/0x25 [633273.946019] [<ffffffff882aedec>] btrfs_file_write_iter+0x2ba/0x3c6 [633273.946019] [<ffffffff8811c9bd>] __vfs_write+0x9a/0xc3 [633273.946019] [<ffffffff8811d0ce>] vfs_write+0xb6/0x160 [633273.946019] [<ffffffff8811dc09>] SyS_pwrite64+0x5c/0x7b [633273.946019] [<ffffffff888e540a>] entry_SYSCALL_64_fastpath+0x1e/0x8e [633273.946019] Code: 89 e6 48 89 df e8 e3 8a 28 00 48 85 c0 48 89 c1 74 41 48 8b 38 48 85 ff 74 39 40 f6 c7 03 74 0b 40 f6 c7 01 75 d9 48 89 f8 eb 2a <8b> 57 1c 85 d2 74 cd 8d 72 01 89 d0 f0 0f b1 77 1c 39 c2 74 04 [633273.946019] RIP [<ffffffff880dd551>] find_get_entry+0x3a/0x69 [633273.946019] RSP <ffff880005f27c78> [633273.946019] CR2: 000000100000001c [633274.291068] ---[ end trace cc1296c118ab43b8 ]---
So it looks like there's some compatibility issue. I ordered new memory module to see if it could be the problem but ti's highly unlikely.
I tried to downgrade to 6.9.3 and it's more stable, but after 1+day of stress testing it also gave up and netgear daemon stoped working. I was able to ssh into the box, there were not kernel crashed but the daemoung has crashed with segfault on restart.
After reboot, system went through initialization and I got to the wizard.
So from my side I have 2 questions, does anyone run legacy model pro4/6 ultra4/6 with WD REDs on OS6 ? if yes what version.
second is how to downgrade back to OS4 ? I found couple link on this forum but all of them are dead
This post has a working link: https://community.netgear.com/t5/Community-Add-ons/Downgrade-to-RAIDiator-x86-from-ReadyNAS-OS-notsupported/m-p/859412#M2683
I'm sure that a lot of people do.
On the memory - did you try running the diagnostic from the boot menu?
- crondAspirant<p>Thanks for the link. </p>
<p>I didn't run memtest, was planning to upgrade memory anyway. </p>
<p>Do you now where did http://netgear.nas-central.org/wiki/Convert_RAIDiator_to_ReadyNASOS go ?</p>
<p> </p>
<p> </p>- StephenBGuru - Experienced User
crond wrote:
I didn't run memtest, was planning to upgrade memory anyway.Ok. Of course bad memory would affect OS 4 also, but perhaps not in the same way.
crond wrote:
Do you now where did http://netgear.nas-central.org/wiki/Convert_RAIDiator_to_ReadyNASOS go ?I don't know who hosted nas-central.org, but the entire site disappeared in mid-August 2018.
The files themselves were maintained by mdgm and were hosted on a Netgear server, but that folder was deleted when he left at the end of August. Hopefully the new links will keep working.
