jasongrimme's avatar
jasongrimme
ReadyNAS Pro 6 not working, booting, but not working
I have an RNP6000 that shutdown on me.  When I boot it up, everything looks fine, it detects all the desk, the status on the admin page is OK, etc.  However, all the file protocols are turned off, if I try to make change changes n the admin page they do not persist.  When I go to the status/logs page, no logs exists.  I tried a firware reset but no luck.  I then took all the drives out and put in 3 different drives, and was able to initialize the unit sucessfully.
So I have a friend at work letting me borrow his readynas pro6 tomorrow, but I'm fearing the worst.  I also have an ultra6 I could move the drives into, but i'm wondering if I'm screwed.  Is it worth booting into tech support mode and asking/paying Netgear to take a look?  I'd hope they'd at least take a look for me, I'm a pretty loyal readynas customer, and willing to buy a 316 or 516 if I can move my drives to it, but I'm afraid it's not a hardware problem :(
  • Is SSH enabled?
    Do you have crashplan installed?
    It could be a full OS partition - which Netgear can fix fairly easily.
  • StephenB's avatar
    Is SSH enabled?
    • jasongrimme's avatar
      jasongrimme
      It was crashplan and a full OS partition, thank goodness someone else on here had it happen to them first (but I do feel bad for the grief it must have caused them :().
        jasongrimme
        just to be complete, in case someone else stumbles onto this thread, here's the issue and how to remedy it.  (putting all steps I used, with detail, so somethings are probably obvious to a lot of ReadyNas uses, but figured having all the steps in one place can't hurt)
        https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-Pro-6-web-admin-and-data-inaccessible/m-p/987674#U987674
        Boot into 'Tech Support' mode
        * power off the NAS
        * push and hold down the reset button (pinhole button on the back)
        * while still holding down the reset button, power on the NAS - after about 15-30 seconds, the screen will display "Boot Menu"
        * release the reset button once the "Boot Menu" is displayed
        * press the backup button on the front of the NAS to scroll through the options until you get to "Tech Support"
          ( NOTE: Be sure to NOT leave this menu on Factory Defaults or choose Factory Defaults, this will erase all your data!)
        * with the menu on 'Tech Support', push the reset button in the back, the NAS will now boot into tech support mode
        Telnet to the NAS
        * telnet to the IP address of the NAS
        * logon with user=root, pw=infr8ntdebug
         (if this PW get's removed, try this link - netgear.nas-central.org/wiki/TechSupportMode)
        Mount the OS partition
        * start_raid.sh
        * mount /dev/md0 /sysroot
        Delete the CrashPlan upgrade files
        * go to the /usr/local/crashplan/upgrade
         - 'cd /usr/local/crashplan/upgrade'
        * remove all the 1*.* files and folders
         - 'rm -rf 1*.*'
        all this info was gleemed from other posts, manuals, etc online, I guess putting it all here so when this happens again to me I can find it :)
ProSupport for Business
