bbb555's avatar
bbb555
Tutor
Jan 18, 2022
ReadyNAS Pro Pioneer Edition OS6.10.6 Missing Volume and Performance Status
Had a drive fail in the NAS while running OS4. I removed the failed drive and ran the volume unprotected and took the opportunity to backup all my data. After the backup was finished, I followed the process to upgrade to OS6 which was successful. Once OS6 was up and running, the existing RAID was converted to X-RAID.  While converting, I added the 6th drive which then expanded the RAID to 6 drives and 9TB usable (6 x 2TB drives).
The issue that I've noticed is that the GUI is not showing anything under the System -> Volume page. It is also showing nothing under System -> Performance -> Status.  Other Performance details Volume, Network, Utilisation, Temperatue are all showing.
Previous when running 6.10.5 and while converting to X-RAID, I could see the volume information.  After conversion to X-RAID, I can't see the physical drives anymore. Upgrading to 6.10.6, still same issue.  I tried reverting 6.10.4, same issue so I've upgraded back to 6.10.6.
RAIDar says the system is healthy, Admin GUI is working correctly, just for those two issues.
Something I'm missing ?
Would be good to see the physical drives again :(
Any help is greatly appreciated.
  • StephenB's avatar
    Have you tried clearing the browser cache?
    • bbb555's avatar
      bbb555
      Tutor
      Tried it on two different machines - desktop and laptop and different browsers on each.
      Clearing cache, cookies etc ... still no luck
      • StephenB's avatar
        Odd.  Any internet security suites running?
  • kohdee's avatar
    kohdee
    NETGEAR Expert
    Does your RNDP600E Admin Page have a serial number that is a MAC Address, or is it a NETGEAR standard 13-character serial number?  You probably need the vital product data reloaded onto the device, which I can assist with if I get a picture of the 13-digit serial number. If it's not the VPD, would need to look at your unit to determine why this is happening. Just to note that we don't officially support RNDP600E with OS 6.
    • bbb555's avatar
      bbb555
      Tutor
      Thanks again StephenB - the firmware versions i tried were 6.10.2 / .4 / .5 / .6 - then reverted back to 6.9.5
      Hi kohdee , totally understand it isn't supported, but appreciate your help.  The system page does show the 13 digit serial number starting with 1YA.  I've pm'd you the serial number. I do have SSH access to the NAS also.
ProSupport for Business
