onyxmueller's avatar
onyxmueller
Readynas Pro Pioneer won't power up
Hello all,
My Netgear ReadyNAS Pro Pioneer does not want to turn back on after a clean shutdown. Early today, I needed to physically move the device to another location. I pressed the front power button twice to shut it down gracefully. Once it was off, I unplugged the device and moved it. Later on, I re-connected all the cables (power, ethernet) and tried to turn the device back on by pressing the front power button... but nothing. It won't turn back on, no matter what I've tried.
Some things I checked/tried:
- Making sure the master power switch in the back is enabled.
- Checked for any loose cables.
- Tried different electrical outlets.
- Left the ReadyNAS completely disconnected for 5+ minutes, hooked the wires back in, and tried to start it.
It seems like the front power button is not triggering the powering of the system. Has anyone experienced anything like this? Please advise. I'm at a loss as to why it won't start after shutting it down normally.
Thanks.
ProSupport for Business
