Hitman202's avatar
Feb 07, 2013
Readynas Pro stuck on boot
I have a Readynas Pro that is refusing to boot.
When pressing the power butten the unit comes on, but goes no further than the Readynas logo on the display.
Disks are spinning up and fans are running.
I have tried the Usb recovery with no succes.
Pressing the reset button on the back with usb key in the backup slot when powering on the unit doesn´t give me the option to toggle betweeen modes (reinstall OS/factory default), it still goes no further than to the Readynas logo and is stuck there.
Could this be a hardware issue??
  • New development.
    I recieved the new Cpu today, didn´t make any difference.
    Tried something new.
    Booted up the system with just one disk (empty disk, not part of the array) and was able to get to the boot menu.
    Tried to perform a "reinstall OS" didn´t work.
    Then did a memory test still with the just one disk, it did 2 passes and no errors.
    Then started up the system without disk 1 and 5 and holy marshmellows, it booted, happiness is at hand;-)
    I´m backing up everything on the Nas right now, so wont touch anything until it´s done.
    The reason for emitting disk 1 and 5 is that I used tray 1 for the "try and see if this works" disk.
    Disk 5 had shown a large amount of reallocated bad sector counts.
    Could this be it??
    That disk 5 was the fault?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Hitman202 wrote:
    Could this be it??
    Probably.
    A good step in troubleshooting an issue like this would be to hook the disks up to a SATA port in a PC one at a time and check them.
    though if it's a faster one than an old one you may see a performance benefit, so it was probably still worth installing it.
  • It´s the same Cpu that was in the Nas from the start (Intel E2160 Dual Core 1.8ghz)
    Right now I´m backing up all the important data on the Nas to other drives.
    This takes a while so I want to get this done with first.
    Next step is to re-insert disk 1.
    A bit hesitant, the unit has been "dead" for well over a week and all of a sudden working.
    So a bit afraid that when I turn it off and put in disk 1 it will revert to the nonworking status.
    mdgm-ntgr
    Yes, finish backing up your data first.
    Put disk 1 back in while the NAS is on. If the disk is good it should be wiped and added to your array
  • Turned off the nas, reinserted disk 1.
    It powered up but didn´t seem to see the "new" disk, still said Volume C is unprotected.
    Next, put in the disk while the system was up, now it is resyncing volume.
    Hoping this means the system will again be redundant when it finishes
  • After resyncing volume with disk 1 the nas seams to be working fine again.
    To some degree.
    Volume C is now i degraded mode (due to the missing disk 5)
    But at least it is booting up every time now.
    The first few days after resyncing it was showing some weird behavior though.
    Boot-up time was a lot slower than normal and Frontview showed several of the disks as beeing dead and Volume C as empyt, but I was still able to access the files on the Nas.
    That seams to have "gone away" by itself now, and the only thing is the display showing "Vol C degraded"
    I spec when I put in a new disk 5 (waiting for mr. postman) that problem will be solved..
    Then when the Nas working, up comes another thing.
    Short story.
    I´ve recently purchased a new router (Netgear r6300) and a wifi ac bridge (Linksys wumc710)
    When hooking up the Readynas to the r6300 via the wumc710 I only get transfer rates at max 8MB/s.
    That´s not very impressive, and even with the bridge located within 10 feet of the router.
    What am I doing wrong?
    I´ve set the MTU on the Readynas and the r6300 to 1500.
    I know this is a bit off topic, but still involving equipment, and hoping someone would have a solution for this??
ProSupport for Business
