xtrips1's avatar
xtrips1
ReadyNAS Pro will not power on
Hello,
My NAS will not power on. This has happened only once in the past and somehow I managed to bring it up to life, after many scrares and efforts, and it worked more than 1 year straight, connected to a UPS without a hitch.
Lately, I went on vacation and forgot about what happened before, so I gracefully shut it down until I came back.
And now it won't power on.
To be more exact, in order to check it I moved it on my desk and hooked it to the power outlet. It didn't work at first, after I forgot about it an hour or so, I came back and it was lit. After I moved it back to where it should be, with the UPS and LAN access it wouldn't power on anymore. And this time it's been 2 days.
Now the questions are?
1) Is it the power supply? I don't know because it randomly lit up previously, it worked fine.
2) Is it maybe the buttons? or the circuitry?
Note: it is not under warranty anymore, and my local distributor says there is no chance of getting new parts for it (!)
3) If I was to get another similar device, of the same generation or later, would I be able to port my 6 HDDs to it with the data on them?
Thanks
  • xtrips1 wrote:
    Ok. It's logical.
    I'll order one.
    Logical, but it could be wrong.  It is the cheapest thing to try though.
  • StephenB's avatar
    Try removing the disks (labeling by slot), and see if it powers up.  If that fails, try shifting it again to your desk.  If it powers up (either step),then  check with RAIDar, and see if RAIDar detects it (and shows "no disk" status).
    If it is the supply, you can replace the PSU in the Pro.  It uses an sfx supply - for instance a SeaSonic SS-300SFD.  https://community.netgear.com/t5/ReadyNAS-in-Business/Spare-ReadyNAS-Pro-6-Power-Supply/td-p/1006575
    Another option is to get a new NAS (RN316 or RN516).  You will need storage to copy your data (the OS 6 NAS can mount the volume, but that is only temporary).  There is more information on that here: http://kb.netgear.com/app/answers/detail/a_id/29876
    • xtrips1's avatar
      xtrips1
      Hello Stephen,
      It looks like you know your stuff. Following my description of events, do you think there is a strong probability that the power supply is responsible?
      Because if you think so, I can try and replace it. That would be an "economically" viable solution for me.
      Along the years this NAS has become secondary, because it became full (15 TB) and I had to add another newer NAS.
      But the data in it is very important to me and it has no backup. Where could I backup another 15 TB anyway?
      BTW, for the moment I tried the first step, removing the HDDs, unsuccessfully.
      I'll try the next one, moving it, tomorrow.
      Thanks
      • StephenB's avatar
        Does anything happen when you turn on the power?  If you see no leds/nothing on the screen/no fan, then the power supply is likely the reason.
ProSupport for Business
