centril
Sep 07, 2016Aspirant
ReadyNAS Ulta 2, No ping/SSH, Loud fan, No leds (except power)
My ReadNAS Ultra 2 (RNDU2000-100PES) is acting up... Operating system: ReadyNAS OS 6.5.1 This is the second time this has happened... but the device was running fine for at least 15 days before ...
BrianL2
Sep 08, 2016NETGEAR Employee Retired
Hi centril,
Welcome to the community!
Could you send in your logs so we can check? Since you got your unit working again, I suggest that you start backing up your files because there's chance that you'll totally lose access to your device. Also, confirm if you enabled volume maintenance on your system.
Kind regards,
BrianL
NETGEAR Community Team
centril
Sep 08, 2016Aspirant
By volume maintenance, what do you mean exactly? Like scheduled scrubbing, defrag, etc? In that case, I have none on the "Volume Schedule" pane.
What logs do you need? File paths of the log files?
Do you want the journald logs, or just the logs on the admin page?
I checked the journald logs right when I turned it back up, and there was just a sudden "outage" in the logs (roughly 2016-09-07 12:30 - 17:30) from when the device went down and up again, and nothing particularly interesting...
Anyways, here are the logs: https://drive.google.com/open?id=0BwBVCjSELCx0ZzlvYjJ6WXk5UWc
Could it be that the linux kernel paniced, and that it didn't have time to log anything?
- mdgm-ntgrSep 08, 2016NETGEAR Employee Retired
Your data volume is nearly 100% full. This is not recommended and is likely the cause of the problems you are facing.
You should free up some space. You should get volume usage back down under about 80-85% full.
