Ado1
Oct 22, 2014Aspirant
ReadyNAS Ultra 6 /dev/md0 is 100%
Hi All, First time poster, long time follower :D My NAS rebooted and started a resync and after some investigation and trolling through the posts, I have discovered /dev/md0 is 100% Filesy...
mdgm-ntgr
Oct 22, 2014NETGEAR Employee Retired
You deleted the log file for ReadyDLNA while the service was still running. Best practice: Don't delete files while they are in use by a process. Stop the process first.
Try
Confirm the space is freed up and then
Also in future rather than deleting it, I would suggest doing e.g.
You may wish to toggle the cache directory for ReadyDLNA onto the data volume. See this x86 add-on: http://www.readynas.com/forum/viewtopic.php?p=392371#p392371
Try
# start-stop-daemon -q -o -K -n minidlna -R 5
# start-stop-daemon -q -S --exec /usr/sbin/minidlna
# echo "" > /var/log/upnp-av.log
