Ado1
Oct 22, 2014Aspirant
ReadyNAS Ultra 6 /dev/md0 is 100%
Hi All, First time poster, long time follower :D My NAS rebooted and started a resync and after some investigation and trolling through the posts, I have discovered /dev/md0 is 100% Filesy...
mdgm-ntgr
Oct 22, 2014NETGEAR Employee Retired
Yes you can install that add-on during the resync, though you can wait too if you prefer. It gets ReadyDLNA to store it's cache on the data volume rather than in /var/cache/minidlna
The log is still stored on the OS partition.
Had you turned debug logging on for ReadyDLNA? Debug logging should be turned off when not needed.
