Ado1
Oct 22, 2014Aspirant
ReadyNAS Ultra 6 /dev/md0 is 100%
Hi All, First time poster, long time follower :D My NAS rebooted and started a resync and after some investigation and trolling through the posts, I have discovered /dev/md0 is 100% Filesy...
mdgm-ntgr
Oct 22, 2014NETGEAR Employee Retired
An OS Re-install leaves data intact.
The touch command updates the timestamp on an existing file or creates an empty file if it doesn't exist.
However you may have other corrupt config files.
You may wish to check if any other files from
/etc/default/config are missing or corrupt e.g. if /etc/passwd is corrupt. If the file is corrupt then you can copy the version in /etc/default/config
