bjr3578
Aug 30, 2012Follower
ReadyShare Cloud on Iphone Help!
I have a WNDR4500 with my external hard drive connected to one of the usb ports on the back. I want to be able to send pictures from my Iphone and Ipad directly to the external drive using the ReadySh...
mdgm-ntgr
Aug 30, 2012NETGEAR Employee Retired
This forum is for the ReadyNAS Network Attached Storage products. I suggest you ask about this issue on the NetGear forums: http://forum1.netgear.com
You may also wish to take a look at https://readyshare.netgear.com/login/ReadySHARE_Cloud.pdf
