sdfjibsdf
Oct 20, 2022Aspirant
"Recover" grayed out in Shares
A folder in shares I'm seeking to "recover" to a computer on my wired Win10 network is grayed out. I would be able to download individual files from this folder, but I need to recover the entire fol...
- Oct 25, 2022
sdfjibsdf wrote:
I can't use Win Explorer to copy or transfer files from NAS to a networked computer.
Why not?
Have you tried entering \\nas-name or \\nas-ip-address in the explorer address bar? (use the real hostname or IP address of course, and be careful to use the correct slash direction).
sdfjibsdf
Oct 25, 2022Aspirant
Yes, exactly. I can't use Win Explorer to to copy or transfer files from NAS to a networked computer.
Maybe I should start a new thread?
Oct 25, 2022Guru - Experienced User
Why not?
- sdfjibsdfOct 25, 2022Aspirant
thx
Does it make sense for the transfer speed to be 10/MBs over cat5, cat 5e, or cat6 through a 1000/MBs switch??
- StephenBOct 25, 2022Guru - Experienced User
Cat 5e or better is what you should be using.
Large files can be copied up to about 100 MB/second if you are copying to an CMR hard drive (internal or USB-3).
But many desktop and USB mechanical drives drives are now SMR, and copying large files to an SMR drive will be a lot slower than 100 MB/s.
Folders with a lot of small files will also transfer much slower than 100 MB/s. 10 MB/s is certainly on the slow side, but there are some scenarios where you can see transfer speeds in that range.
How much data are you copying?
1,300 files, 280 GB.
Eh. it's fine. I'll just do it overnight. (it's transferring to a sata platter HDD)
Thx
