theluke79
Jan 10, 2015Aspirant
Rename Volume RN102 JBOD
Hi!
i have a RN102 fw 6.2.2
2 Disks: 2TB & 3TB
No SCSI is configured, just JBOD, the volumes are "indipendent".
I want to change the names of the 2 volumes, how can I do it?
Seems impossible!
2 Disks: 2TB & 3TB
Seems impossible!
- mdgm-ntgrNETGEAR Employee RetiredRenaming existing volumes is not something we support.
You could backup your data, delete the volumes (note all data on a volume is lost when you delete it so you must backup your data first), create new volumes and restore your data from backup. - theluke79AspirantOk, i will keep the old names... No problems
Too much hassle for just name label - StephenBGuru - Experienced UserAlso, some apps look for /data so its good to keep that volume name.
