NASklr
Sep 17, 2015Aspirant
Restoring a RN102 After Factory Reset
I'm considering refreshing my RN102 after botching the snapshot folders. It has two 1TB disks in a RAiD1 config, and currently has 20GB of space left. I couldn't tell easily how much of that was held...
- Sep 17, 2015
It would have been better to delete the snapshots from the admin web ui.
NASklr wrote:
I'm considering a vertical expansion by replacing the 1TB drives with 3TBs (current sweetspot for $/GB on WD reds.) I have two usb external 1TB drives I use for alternating backups that I will also upgrade to 3TB.
1) Is it plausible to save the current RN102 configuration, restore to factory defaults, replace the drives with 3TB units, restore the saved RN102 configuration, then copy over backed up files to the shares on the freshened-up 102?
Yes, but also uninstall any apps you installed before you save the configuration. Also, reinstall them after you restore the configuration.
2) Would this clean up the mess I made out of the snapshots (I don't mind losing the old ones)? I've turned off snapshots on all shares for now until I complete this move.
Yes.
3) Is there some sort of Moore's Law that file size _and_ file number will double every year? ;-)
Data overall is growing faster than Moore's law. Though that doesn't mean yours has to of course. :smileyhappy:
Sep 17, 2015Guru - Experienced User
Yes.
- NASklrSep 17, 2015Aspirant
Cool. I'll give it a try.
