Mr_Resetti80
Oct 31, 2014Aspirant
[RN102] Jbod boot up problem
Hi, I bought the RN102 to upgrade from the previous ReadyNAS Duo. I'm running Win 7 sp 1 on a Zotac Ci320 nano. I setup the RN102 to run with Flex raid and JBOD configuration. I put in two disk ...
vandermerwe
Nov 01, 2014Master
I would still ask support, they should help you.
Although you swapped out the disk that was in slot 1, there is no reason I can see why the volume on disk 5 should not still be accessible.
