Mr_Resetti80
Oct 31, 2014Aspirant
[RN102] Jbod boot up problem
Hi, I bought the RN102 to upgrade from the previous ReadyNAS Duo. I'm running Win 7 sp 1 on a Zotac Ci320 nano. I setup the RN102 to run with Flex raid and JBOD configuration. I put in two disk ...
Nov 01, 2014Guru - Experienced User
jbod is fine, popping disks in and out a lot is the bad idea. One reason is that the SATA connectors on the drive are not designed for frequent insertion/removal.
