Mr_Resetti80
Oct 31, 2014Aspirant
[RN102] Jbod boot up problem
Hi, I bought the RN102 to upgrade from the previous ReadyNAS Duo. I'm running Win 7 sp 1 on a Zotac Ci320 nano. I setup the RN102 to run with Flex raid and JBOD configuration. I put in two disk ...
Nov 01, 2014Guru - Experienced User
I use jbod on my backup NAS, but the disks remain in place. The idea is simply to maximize space.
With RAID you get a single volume, so you don't need to move files from disk to disk at all. Though given your current storage needs, I think an RN104 would have been a better choice than the RN102. Then you could fit everything on 2x4TB with single-failure protection and grow storage by adding a third 4 TB drive.
Though you can migrate the RN102 disks to an RN104 later on with no data loss.
