iany
Sep 21, 2016Guide
RN104 immediately "out of memory 390" error after 6.2.2 -> 6.2.5 -> 6.4.2 upgrade
I decided to upgrade my 2+ years old 6.2.2 firmware to a newer stable one. The latest in 6.4 branch seemed OK -> about 9 months old, so I thought it's been proven. I wasn't wrong, I just missed all t...
- Sep 23, 2016
I'm not out of the woods yet, but I've made considerable progress.
I was able to boot in "volume read-only" mode which was reassuring. At least I'd be able to backup the data...
So, I tried to find what's actually happening in the system. So I logged in via SSH and watched the system utilization. As soon as the data volume was mounted, btrfs-cleaner process appeared. It pegged the CPU to 100% which wouldn't be a problem in itself. But it also consumed more and more memory and when the system started to swap, it ground to halt. I made another test--booted in "volume read-only" mode, logged in as root and executed `mount -o remount,rw /data`. The outcome was the same--btrfs-cleaner ate all memory, swapping started, the system halted. Again, the finger was pointed at either snapshots (too many to process etc.), or quotas (newly introduced feature).
After another "volume read-only" mode boot-up, I executed this:mount -o remount,rw /data;btrfs quota disable /data
and the system stayed OK, no btrfs-cleaner, nothing. So I remounted all other btrfs filesystems (get the list with `mount | grep btrfs`). In my case:
- the list of btrfs volumes:-/dev/md127 on /data type btrfs (rw,noatime,nodiratime,nodatasum,nospace_cache,subvolid=5,subvol=/) /dev/md127 on /apps type btrfs (rw,noatime,nodiratime,nodatasum,nospace_cache,subvolid=257,subvol=/.apps) /dev/md127 on /home type btrfs (rw,noatime,nodiratime,nodatasum,nospace_cache,subvolid=256,subvol=/home) /dev/md127 on /var/ftp/home type btrfs (rw,noatime,nodiratime,nodatasum,nospace_cache,subvolid=256,subvol=/home) /dev/md127 on /run/nfs4/data/Shared type btrfs (rw,noatime,nodiratime,nodatasum,nospace_cache,subvolid=275,subvol=/Shared) /dev/md127 on /run/nfs4/home type btrfs (rw,noatime,nodiratime,nodatasum,nospace_cache,subvolid=256,subvol=/home)
- the commands to remount and disable quotas:-
mount -o remount,rw /home;btrfs quota disable /home mount -o remount,rw /apps;btrfs quota disable /apps mount -o remount,rw /var/ftp/home;btrfs quota disable /var/ftp/home mount -o remount,rw /run/nfs4/home;btrfs quota disable /run/nfs4/home mount -o remount,rw /run/nfs4/data/Shared;btrfs quota disable /run/nfs4/data/Shared
Note that /run/nfs4/data/Shared is my NFS share and you won't have it for sure. Your list may be very different.
Still no btrfs-cleaner, the system still running OK. So I removed all snapshots (note: I was not using them at all, your set up might be different, but you may need to do so too in order to restore the system).
How to remove snapshots--well, first you need to have a list of configs--they're actually numbers and their count corresponds with the btrfs volume count:-ls /etc/snapper/configs
You can also find out which config is for which volume (the smileys are actually a colon and capital S):-
root@kostka:~# grep VOLUME /etc/snapper/configs/* 0:SUBVOLUME="/data/Backup" 1:SUBVOLUME="/data/Documents" 2:SUBVOLUME="/data/Music" 3:SUBVOLUME="/data/Pictures" 4:SUBVOLUME="/data/Shared" 5:SUBVOLUME="/data/Videos"
Then execute for each config:
snapper -c <config> list
It'll show you something like:
Type | # | Pre # | Date | User | Cleanup | Description | Userdata -------+-----+-------+----------------------------------+------+---------+-------------+---------------------- single | 0 | | | root | | current | single | 13 | | Thu 31 Mar 2016 12:00:41 AM CEST | root | | | snapshot=c_1459375241 single | 43 | | Sat 30 Apr 2016 12:00:25 AM CEST | root | | | snapshot=c_1461967225 single | 74 | | Tue 31 May 2016 12:00:49 AM CEST | root | | | snapshot=c_1464645648 single | 104 | | Thu 30 Jun 2016 12:00:25 AM CEST | root | | | snapshot=c_1467237624 single | 134 | | Sat 30 Jul 2016 12:00:20 AM CEST | root | | | snapshot=c_1469829619 single | 135 | | Sun 31 Jul 2016 12:00:51 AM CEST | root | | | snapshot=c_1469916051 single | 141 | | Sat 06 Aug 2016 12:00:58 AM CEST | root | | | snapshot=c_1470434458 single | 148 | | Sat 13 Aug 2016 12:00:05 AM CEST | root | | | snapshot=c_1471039205 single | 155 | | Sat 20 Aug 2016 12:00:25 AM CEST | root | | | snapshot=c_1471644025 single | 158 | | Tue 23 Aug 2016 12:00:08 AM CEST | root | | | snapshot=c_1471903208 .. cut = there were daily snapshots .. single | 181 | | Thu 15 Sep 2016 12:00:21 AM CEST | root | | | snapshot=c_1473890421
And now you clean all of them, but the current. The command is `snapper -c <config> delete 1-<no. of the latest snapshot>`, in my case e.g. `snapper -c 0 delete 1-181`. They were all zero-size, so it took less than a second.
I then rebooted to normal mode. The current state of the system is:-
- Snapshots deleted and all snapshotting disabled.
- Quotas disabled. It's for sure unsupported by Netgear. Some things may be broken. Firmware upgrade may enable them or fail because of them being disabled. Etc.
- I'm now balancing, defragging and scrubbing the volume. I haven't found in which order it's best to do this, the guidance in Netgear's KB #26941 is to scrub rarely, defrag occasionally and balance regularly. My 6 TB volume took 10.5 hours to balance, 4.5 hours to defrag and it took 13 hours to scrub to 30%.
Next steps:-
- Verify data integrity.
- Enable quotas and see if the system comes up normally.
bedlam1
Sep 21, 2016Prodigy
If you click the "Downloads" link at the top of this page, enter your model no., tick firmware (or all) you will find a whole bunch of release notes
mdgm-ntgr
Sep 22, 2016NETGEAR Employee Retired
The firmware release notes already link to KB article #26212, and the very first link on 26212 links you to the 30033 article you mentioned.
- ianySep 23, 2016Guide
Well, I know I overlooked it, but "always" is unfortunately a bit of a overestimation in this case. Instead of one link to #26212, you get two links in 6.4.1 and 6.4.2 rel. notes which point to non-existent documents--#23113 and #22804. And you need to search for 6.4.2 rel. notes as these are missing from the Downloads page.
Given the fact that this procedure may crash the machine, I'd really suggest more aggresive wording. IMPORTANT or WARNING are such a good words to attract attention... Or bold red lettering is also good. Something for the people like me... "Take into consideration" is too mild in my opinion.
