martyn20
Jul 03, 2014Aspirant
RN104 New Volume
Could not see this particular problem, forgive me if I have missed it and started another thread for nothing.
I have a new RN104, I started it for the first time with a new 4TB disk and followed the instructions on the little set up guide. including registering online. Having realised it was not simple to add more disks I decided to buy another disk and add it before I put anything on the memory. I loaded the second disk 4TB again, new and identical to the first, did the factory reset, and waited 'several' hours until the volume was rebuilt. The machine shows I have 2 disks (2x4TB) but only lists available space as 3.63TB, same as before I added the 2nd disk. I have done the factory reset again and waited the 12 hours or so but it still says the same. I have included a screenshot
I know a bit about computers but nothing about NAS and I am using this forum as my guide.
- With RAID-1 the two disks are mirrored, so adding the second drive does not add capacity - it adds redundancy. If you hot-insert a third 4 TB drive the space will increase to 7.2 TiB, and the NAS will switch to RAID-5. You still have redundancy which protects against a single drive failure.
If you wanted jbod (no RAID) then you should start over with another factory reset (with only one drive installed), switch to FLEXRAID/JBOD, and hot-insert the second drive.
Adding a new disk to the RN104 is easy, I am puzzled by your comment on "not simple to add more disks".
- berillioAspirantthanks mdgm. give me few minutes, I need to move it from where it is, I can't access both front and back simultaneously
- berillioAspirant??? I thought that it would be like the RAM check when a pc boot up.... 9 minutes and continuing.... 11.. 13... how long does it normally take? More important, will any message STAY until I go out of the menu, or I have to stay and catch it before it disappears? 16:30..
- mdgm-ntgrNETGEAR Employee RetiredI think the test runs for about 4 hours. This is an extended memory test.
- berillioAspirantthanks mdgm. it has just done 1h now, I did put a camcorder on it . . I'll report tomorrow, it's 2:30am in the UK
- berillioAspirantmdgm, Stephen: returning to the original post
viewtopic.php?f=20&t=78671
I will also put a link there to this post, for further reference - Hi all. I had 3x3TB caviar red hdd into my rn104. Last week I hot install the 4th, wait it to rebuild but at the end not increase the capacity, it remain to 5.5 tbyte. I read about to reboot the system and I did also but remain to 5.5 instead of 9. Have you suggestions? Thanks a lot.
Try downloading the logs, and look in mdstat.log and volume.log for the status of the newly added disk.
hi, mmmm, seems to be not into the raid...
Number Major Minor RaidDevice State
0 8 18 0 active sync /dev/sdb2
1 8 34 1 active sync /dev/sdc2
2 8 50 2 active sync /dev/sdd2
3 8 2 3 active sync /dev/sda2
/dev/md/Server-0:
Version : 1.2
Creation Time : Wed Sep 9 06:57:33 2015
Raid Level : raid5
Array Size : 5850833664 (5579.79 GiB 5991.25 GB)
Used Dev Size : 2925416832 (2789.89 GiB 2995.63 GB)
Raid Devices : 3
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Wed Nov 30 18:49:36 2016
State : clean
Active Devices : 3
Working Devices : 4
Failed Devices : 0
Spare Devices : 1
- I shut off the nas and remove the hdd. Download the WD software and clean the hdd. I let you know. Thanks a lot :-)
