jay_johnson
Dec 27, 2010Aspirant
Rsync Between PBX-In-A-Flash VoIP Server and ReadyNAS NVX
Guys, I'm looking at installing a VoIP solution for a small business and I'd like to be able to use Rsynch between the PBX and ReadyNAS NVX (for testing). The actual unit that PBX files will be ba...
Paul_Sadlik
Oct 26, 2011Aspirant
jay.johnson wrote: Guys,
I'm looking at installing a VoIP solution for a small business and I'd like to be able to use Rsynch between the PBX and ReadyNAS NVX (for testing). The actual unit that PBX files will be backed up to will be a ReadyNAS PRO. Prior to doing this job, I'm looking at testing this in my home office first.
I've successfully used Rsynch between my NV+ and my NVX but I've never done this between a Linux based machine (PBX In A Flash) and my NVX.
Has anyone used rsynch between the two, and if so, what was the approach used and how would you initiate the session in Linux to transfer files over to the readynas (and vice-versa)?
Thanks...
Jay
There are many solutions that you can opt for. Here are two companies that i have personally used and they would surely help you save money.
The first one is Axvoice with two business plans. SOHO for home based businesses and the small business plan for more upscaled businesses. I would recommend the SOHO because it has all you need.
http://www.axvoice.com/plans/hosted-pbx.html
The second plan is from Vonage, the all out VoIP service with lots of benefits offered to the customers. They also have a handy plan for small business owners. I hope you would be able to greatly benefit yourself from it.
http://www.vonage.com/us-canada-calling-plans/small-business-voip-unlimited/?refer_id=WEBSR0706010001W1&lid=sub_nav_sb_unl
