kiran_kankipati
Oct 11, 2018Guide
Rsync setup between NETGEAR ReadyNAS and FreeNAS
Hey guys, Today I managed to setup a working Rsync connection between my FreeNAS and NETGEAR ReadyNAS servers. I shot a detailed video of all the steps. FYI, in my scenario, I am using my FreeNAS as ...
Herrieman
Jan 10, 2019Aspirant
Hi Kiran,
Your video came just in time: I just built a Freenas setup recentely. However, I do not seem to be able to find my Freenas server on my Readynas.
When I try to create a new backup task on the Readynas I fill in the IP address of my Freenas system where it says "Host". My Readynas however is not able to detect the Freenas system. When I click "Discover" it scans for about 1 second before reporting that it could not find any Rsync servers.
The Rsync service is enabled on my Freenas. Also I can ping both devices without any issues, they are on the same subnet.
I even tried to start with the Freenas setup (creating a new Rsync module, creating an Rsync task on the Freenas) but none of this has helped me. Was there perhaps a step or two that you had to perform before being able to connect the Readynas to the Freenas which you did not show in your video?
Thanks in advance,
Herrieman
- StephenBJan 11, 2019Guru - Experienced User
You don't need to discover, you can just enter the appropriate path.
- HerriemanJan 12, 2019Aspirant
Hi StephenB,
I think I found it: suddenly after a reboot it worked. At first I had no idea why, until I saw that my VPN application had not connected. I think this is what caused the issue.
Strange thing though: I even tried on Linux Mint and it gave me the same error message. On Windows it works now.
Thanks for your time and tip.
Herrieman
