beack
May 12, 2011Aspirant
rsync uid 4294967295 (-1) is impossible to set on...
Hi there. I have a problem with rsync backup on my ultra 2. I have some backup jobs running rsync, connecting to a windows machine running the deltacopy rsync server. Files are copied from the...
beack
May 13, 2011Aspirant
Hi Stefan.
Thanks for your reply.
All the files are copied, so the backup works.
But the job returns failed as a result of this check, and the backup logs get very large very quickly, as it is a check performed on every file, not just the ones backup up by the incremental job.
/Beack
/Beack
