beack
May 12, 2011Aspirant
rsync uid 4294967295 (-1) is impossible to set on...
Hi there. I have a problem with rsync backup on my ultra 2. I have some backup jobs running rsync, connecting to a windows machine running the deltacopy rsync server. Files are copied from the...
bspachman
May 15, 2011Aspirant
FWIW, I can confirm this behavior. A log full of "uid is impossible to set" and "gid is impossible to set"....
It does look like the files in the backup are being copied and pruned properly, so hopefully this is merely a cosmetic issue, and there will be no nasty fallout later...
brad
brad
