beack
May 12, 2011Aspirant
rsync uid 4294967295 (-1) is impossible to set on...
Hi there. I have a problem with rsync backup on my ultra 2. I have some backup jobs running rsync, connecting to a windows machine running the deltacopy rsync server. Files are copied from the...
mdgm-ntgr
Jan 06, 2012NETGEAR Employee Retired
silent-k wrote:
Can you tell me... when a new version of radiator comes out will it automatically overwrite the old version of rsync with whatever version is packaged in radiator?
Yes, but a bug has been filed for it (at least on Sparc) and it will be fixed so newer Rsync works: http://www.readynas.com/forum/viewtopic.php?p=332968#p332968
Not sure if it's already fixed in 4.2.20 betas or not, but if not hopefully it will be.
