IvanVSA
Aug 07, 2017Aspirant
Samba doesn't work anymore
Hello, pals!
Today i'd face the problem with samba on my RN104. After turning the server off and that turned it on everything seemed ok unless i couldn't reach the server via samba. When i tryed to turn the SMB service on from web interface it delayed for 5-10 seconds and then nothing happend. It still off! Please help!
I have ReadyNAS 104 server, sw ver. 6.7.5
FTP and SSH connections are ok.
Here was very similar problem solved with overwriting default config file. But i have no idea which file to overwrite and were i could find the source for it
Dear Skywalker!
Thank you for help and response. Actually, i tryied to reinstall samba, meditated on logs but finally made OS Reinstall and that helped. So i can not try your advise but anyway thank you!
- SkywalkerNETGEAR Expert
Well, I can't tell how it happened, but I can tell you how to fix it. These two commands should take care of it:
# rm /usr/lib/arm-linux-gnueabi/libwbclient.so.0.13 # ldconfig
- IvanVSAAspirant
Dear Skywalker!
Thank you for help and response. Actually, i tryied to reinstall samba, meditated on logs but finally made OS Reinstall and that helped. So i can not try your advise but anyway thank you!- IvanVSAAspirant
UPD!!!
As i wrote before i made OS Reinstall and after it was done at the first reboot Samba starts properly. But after that i made next reboot and the problem accure again.There is a quote from console:
Spoilerroot@vsa_moscow:~# rm /usr/lib/arm-linux-gnueabi/libwbclient.so.0.13
root@vsa_moscow:~# ldconfig
/sbin/ldconfig.real: libraries libsnapper.so.2.1.0 and libsnapper.so.2.5.0 in directory /usr/lib/arm-linux-gnueabi have same soname but different type.
/sbin/ldconfig.real: /usr/lib/libreadycloud.so.1 is not a symbolic link
