atai1
Mar 30, 2015Aspirant
Share problem NV
Hello,
I have a problem creating a new share on my NV.
I have added a new volume and when I try to create a new share on this volume I can't then access from windows XP or 7.
Anytime I try to map the network drive using the share created the system ask me for a password but there is no password set up on the share that I have created.
The share has been created using the same option that I have set up for all the other shares.
I have also created a new share for a different volume but I have the same problem.
Any idea why this is happening?
Thanks
Thanks
- StephenBGuru - Experienced UserIf you set up the share to "everyone" access in user mode, then no password is needed. This works perfectly for me with several players (WDTV Live, EVA9150, NTV550).
You shouldn't need to go back to the old mode, what you need to do is fix your permission.
Perhaps you can tell us your settings for one of the media shares? - atai1AspirantThanks you very much for your help!
Can you explain me how to insert the print screen on the message so I can attach all my set up to explain better? - StephenBGuru - Experienced UserYou need to create jpg screen shots, and post them on a publicly available internet server. Then you can wrap the URL to the jpg with the tags (using the img control in the full editor).
- atai1AspirantOK let's try.
I am sorry for the italian language but even if I switch the language to English I still have the italian language
http://imgur.com/gpGWVbD
http://imgur.com/yUpgzv4,fWTWZ2s,EPiKe7h#0
I hope this is enough otherwise please let me know what do you need to see
Thanks - StephenBGuru - Experienced UserThe Italian does make it a bit tricky.
Let's work it the other direction (using the English UI ...) The steps below will adjust your share permissions so that all files/folders can be accessed by any device on your local network w/o a password. So try this on one share, and then maybe reboot the media player and try again. These steps apply to user security mode.
Select "shares", the "share listing", and select the "CIFS" icon next to one of the shares.
Set the Default Access (next to the share name" as "Read/Write"
Check the box next to "allow Guest access" under "Share Access Restrictions".
Scroll down to "advanced cifs permissions" and check the box next to "automatically set permissions on new files and folders". Set the group rights and everyone rights to "read/write".
Then click apply (lower right).
Now click on the "advanced options" tab on the upper right.
Set the Share Folder Owner to "nobody" (without the quotes).
Set the Share Folder Group to "nogroup".
Set folder group rights to "read/write"
set folder everyone rights to "read/write".
check the box next to "set ownership and permissions..."
check the box next to "grant rename and delete privileges to non-owner of files".
Then click apply again.
The checkbox next to "set ownership" will immediately clear - that is normal. The permissions will be changed in the background - after a while a pop-up will tell you it is complete. - atai1AspirantYou are amazing!!!
Everything works now
THANK YOU VERY MUCH
