Keligh
Sep 18, 2017Tutor
Shares goes read-only after a while after upgrade to 6.8.0
Hi, After upgrading to 6.8.0 I have a strange behavior. After every boot, everything is fine for some time (up to half an hour) and then file system goes read only. After boot: root@NasSeb...
- Sep 21, 2017
This morning I gave up: didn't see any possible solution as the more I looked the it seemed the raid itself became corrupt (not read/write error in the smart data of the disks)
=> I just did a factory default and am downloading my last backup
Marty_M
Sep 21, 2017NETGEAR Employee Retired
Hello Keligh,
It does appear that after firmware upgrade the NAS will for some reason will automatically go to read only mode. I have not seen similar concern/issue raised on support. When the NAS goes to read only mode do you need to reboot the NAS to work again and in turn goes to a cycle is this correct? May we ask for the complete logs of the NAS, you may use file sharing website like wikisend and just PM the download link.
Marty_M
NETGEAR Community Team
Keligh
Sep 21, 2017Tutor
