LI150
Sep 09, 2013Aspirant
Single blinking green light HDD light on Duo? What's wrong?
I've tried searching the forum for help but can't find what I'm looking for.... Can anyone tell me what's wrong with my Readynas Duo? I have one green flashing HDD light flashing at a constant spee...
LI150
Sep 10, 2013Aspirant
I don't have the data backed up... The 2 drives are mirrored so should have the same data on them. I've purchased another drive as I assumed the drive was dead only to find it didn't work in bay 1 also. I then swapped the original drives over to find out bay 1 still didn't work - at this point I finally concluded whatever I put in bay 1 doesn't work.
My plan is to keep one of the original drives as my back up and use the other original drive and new one if I can only get bay 1 working.
What do you guys suggest (your help is appreciated by the way )
Sent from my Nexus 10 using Tapatalk 4
